аэрограф + компрессор, страшно выгодно
У самого давно уже спармакс, но вот наткнулся у друзей китайцев компрессор + аэрограф http://www.dhgate.com/p_ff808081388cd37701388f01b20978d9.html , для начинающих за 1800р да еще и с доставкой - просто шик:) Уже 3й год на этом ресурсе тарюсь - без нареканий, будут вопросы пишите мне на почту ledigital@mail.ru вот еще всем известный миол http://www.dhgate.com/new-0-3mm-spray-dual-action-airbrush-gun/p-ff808081331b1a74013362e7be576dda.html всего 16 уев ;)
А при чем тут тату - Airbrush Tattoo Supplies Portable Makeup Mini tattоо???
И скоко у него давление??
Изменено: bek - 02.11.2012 20:24:30
The tattoo compressor Used with the airbrush( diameter 0.2-0.5mm), elegant morden design, widely been used inrange of art painting,body painting,make up industrial etc.Easy to use without professional ways,adjustable speed control at 5 levels, you can use it freely and easily at different requirements.
Condition: Brand New
Color : White with black
N.W.: 1000 g
Power: DC12V
Max output/min: 15L/min
Voltage input: 12V
Current input: 0.8A
Max Pressure: 19psi / 1.3BAR
Advantages:5 speed 24 hours working
Package Contains:
1.1 pcs mini tattoo compressor
2.1 pcs Airbrush gun
3. 1pcs Airhouse & 1pcs Plug and 1pcs foothold
How to use :
1. Assemble the airbrush, hose and compressor together and make sure compressor put to the steady position. The airbrush should be single action type.
2. Plug AC cord to the compressor then connect the AC adapter to the electrical source. The adapter`s output voltage is 12V and current is 2A.
3. Press ON/OFF to OPEN/CLOSE the compressor.
4. Press MODE to control the speed of air fluid.
Attention:
1. Don’t change the MODE level Quickly
2. The compressor should be put in dry,clean and Ventilates place
3. Don’t let children contact and play
4. The compressor’s ambient temperature should be in 0~40 degree and don’t  put in solarization.
5. Please put the airbrush to the holder when you don’t use .
This item has US Plug and Eur Plug,if you have special requirement,pls leave a note in the order comment when you place the order,otherwise,we will automatically choose the plug according to your shipping country.apprecitae your understanding
Я не разбираюсь особо в компрессорах и аэрах, но хочу бюджетный вариант приобрести)
Вот на ютьюбе увидел рекламу комплекта, как здесь, только тот розовый был :)
Что скажете про него, можно начинающему им красить, если с бюджетом проблемки?
А я чё?Я ничё!Другие вон чё и ничё!А я чуть чё, так сразу вон чё!
Никто не может оценив хар-ки сказать пригоден ли он для покраски моделей?
хех... купил себе на прошлой неделе http://www.ebay.com/itm/Gravity-Dual-Action-Airbrush-Set-Compressor-Kit-Air-Filter-Hobby-Cake-T-Shirt-/200884734673?pt=LH_DefaultDomain_0&hash=item2ec5a9cad1
Сейчас занимаюсь покраской своей первой модели. На пробных поверхностях штука просто супер показала себя.
Есть автостоп, не плюется, и цена комплекта мне получилась с доставкой в Украину 500грн.
П.С. Грунт нанесло просто изюмительно.
Добрым словом и револьвером можно добиться большего, чем одним добрым словом.
Владимир Цахилов пишет:
хех... купил себе на прошлой неделе http://www.ebay.com/itm/Gravity-Dual-...2ec5a9cad1
Спасибо за наводку) Отпишитесь пожалуйста, когда покрасите модель)
вот тут ещё можно взять http://www.aliexpress.com/item/Portable-Makeup-Airbrush-Mini-Air-Compressor-with-Black-5-Speed-Airbrush-tattoos-24-hours-Continus-Working/579266272.html
работа тем аерографом что я линкавал. (1й етап)
Красиво) А что за краска у вас?
Про аерограф.
Отлично работает с красками и грунтами Тамия с пропорциями 1/1. Краски+спирт, Грунт + 646БП. Из нареканий только отвратительного качества фильтр влаги. Но ето капля дёгтя в море счастья.
П.С. Через недельку модель закину в песочницу. За кепками и табуретками.
Про аерограф.
Ну а фильтры, смывки и все такое будет?)
Всё будет - но к аерографу и компресору ето не относится. )
Ну это понятно, просто интересно)
Интересное, конечно, предложение. Давно уже задумался о покупке аэра, но цены далеко не демократичные... А здесь совсем недорого. Автор или кто-нибудь еще может что-нибудь сказать по поводу работы сего набора? Качество хорошее или Китай Китаем?
"Academy" Tiger Mid (с интерьером): 20%
"Dragon" Elefant "Premium Edition" - 1% (руки-крюки боятся испортить)
Илья Вирник пишет:
Товарисчь, разуйте глаза и почитайте сообщения выше)
Андрей Рузанов,
Так там сообщение про аэр с иБея и стоит он 80$ + 80$ доставка. А я спрашиваю конкретно про первый на китайском сайтике :)
Илья Вирник пишет:
Андрей Рузанов,
аэр для тату
никита,
Насколько он подходит для окраски моделей? Использовать можно?
Илья Вирник пишет:
никита,
Илья, не ищите где дешевле, как правило это оканчивается сильным расстройством. Нормальный аэр выходит в ценнике района 2000 рублей с пересылкой. И ценник обусловлен не прихотью, а качеством материалов и собсно качеством их обработки. Сильно сомневаюсь, что на аэрографе за 450 рублей будет корпус из нержавейки и из нее же сопло, скорее всего силумин и латунь. А это значит, что аэр очень быстро разболтается и скорее всего, сразу дуть будет куда ему угодно, а не куда надо Вам. Я бы поостерегся. Вы ведь инструмент покупаете не на два вечера, хохмы ради, возьмите сразу более менее нормальный агрегат. Вариантов масса. Из проверенных и безотказных - Фенга и Инкед - отличные рабочие и недорогие аэры. Компрессор я бы то же от Фенги брал. И не заморрачивался поиском дешевой альтернативы. Бо черевато это все.
Злой Админ!
как классно некурить!\0/ )^(
Вы уж простите, но роспись бодиарта, холодильников, авто и моделек делают одними и теми же аэрографами, все зависит от диаметра сопла. Если оно к примеру 0,2мм то металики не пролезают, а вот сопла 0,5 можно использовать практически со всеми красками. Можете залезть на сайт магазина "Черная речка", у них там вроде расписано какой аэр для чего рекомендуется использовать. И еще раз повторюсь - все зависит от диаметра сопла и пигмента краски.
ну вроде неплохой....и смотрю он почти одинаково везде стоит ну и +/-.......
