вот мне тоже интересно... Хотя на западном сайте видел чо там не то(почти всё) вот: Kazutaka YOKOTA I boutht DML #6301 „Pz.IV ausf E mit Vorpanzer“ last Friday. I have not yet started building it, but checked spurs and compared parts against those in DML’s first Pz.IV ausf E “3 in 1” kit (#6264).
I am pleased to report that it appears DML has corrected quite a lot of parts. It is amazing that they managed to do this in a very short period of time since the release of the #6264 kit. There still are some points which I would like to see corrected. But this kit, #6301, is vast improvement over #6264, and, in my opinion, this is the way #6264 should have looked in the first place.
I would like to expect their forthcoming Pz.IV B, C, and D kits will have more improvement, and will be better than ever.
I. Items which were wrong in #6264
1. Lower Hull and Running Gear 1.1 Chassis length:- #6264:too long, #6301:FIXED 1.2 Space between bogies:- #6264:too wide, #6301:FIXED 1.3 Position of the first return roller:- #6264:wrong, #6301:FIXED 1.4 Diameter of the return roller:- #6264:too large, #6301:FIXED 1.5 Bolts on the sprocket wheel:- #6264:wrong, #6301:FIXED 1.6 Position of the sprocket wheel:- #6264:too low, #6301:FIXED 1.7 Front armor plate of the lower hull:- #6264:wrong, #6301:FIXED 1.8 Conical bolts on the armor for the final drive housing:- #6264:too few, #6301:FIXED 1.9 Glacis plate:- #6264:wrong hatch positions, #6301:FIXED 1.10 Rear armor plate:- #6264:lacking details, #6301:NOT fixed 1.11 Exhaust muffler:- #6264:lacking details, wrong position, #6301:NOT fixed 1.12 Cooling water drain port :- #6264:not correct, #6301:FIXED
2. Upper Hull 2.1 Hull MG ballmount:- #6264:too small, #6301:FIXED 2.2 Front visor for the driver:- #6264:not good, #6301:FIXED 2.3 Turret splash guard:- #6264artially wrong, #6301:FIXED 2.4 Keyhole plate on the radio op hatch:- #6264:upside down, #6301:FIXED 2.5 Keyhole on the radio op, the driver, and turret hatches:- #6264:wrong shape (round) , #6301:NOT fixed (should be rectangular) 2.6 Position of the shovel on RHS:- #6264:wrong, #6301:FIXED 2.7 Width of the front armor:- #6264:narrower than the lower hull (by about 1mm) , #6301:NOT fixed?
3. Turret 3.1 Position of the hatch stopper on the turret side:- #6264:wrong, #6301:FIXED 3.2 Turret font armor plate:- #6264:wrong shape, #6301:BETTER shaped 3.3 Visors on the turret front:- #6264:wrong position, #6301:BETTER placed 3.4 Co-axial MG:- #6264:wrong position, #6301:FIXED 3.5 Turret rear shape:- #6264:not quite correct, #6301:NOT fixed
II. Items about which there is some doubt, but I am not sure these should be classified as errors...
4. Lower Hull and Running Gear 4.1 Dumpers:- #6264:not quite look correct?, #6301:as before 4.2 Drive sprocket wheel hub:- #6264:not protruding enough?, #6301:as before 4.3 Road wheel hub:- #6264:not protruding enough?, #6301:as before 4.4 Radiator access hatch on the rear armor:- #6264:too large?, #6301:as before 4.5 Aux-engine muffler:- #6264: not quite correct shape?, #6301:as before
5. Upper Hull 5.1 Round hatches on the radio op and the driver hatches:- #6264:too thin?, #6301:as before 5.2 Shape of side visors:- #6264:not quite correct?, #6301:as before
6. Turret 6.1 Turret side hatches:- #6264:too wide?, #6301:as before 6.2 Gepaeckkasten:- #6264:too large?, #6301:as before
У меня 6301 был, к слову)) Обзор этот я читал, ничего такого.
Слегка поразило -- 2.5 Keyhole on the radio op, the driver, and turret hatches:- #6264:wrong shape (round) , #6301:NOT fixed (should be rectangular) Это конечно круто, что он должен быть прямоугольным, но я думаю, что таких крупных планов делать никто не будет))
По большому счету -- таких ошибок можно нарыть много. Главное осознать для себя, где остановится.
"Я их переделывать не буду! Лень." Если бы не лень -- то все бы переделал? )))
..а всякое компактное множество в банаховом пространстве сепарабельно %))
Тогда вообще не понятно зачем было тему открывать. Спрашивал как сделать правильный, и тут же говоришь что переделывать не будешь. Где логика?
Расскажи Богу о своих планах на будущее... пусть ОН повеселится... [SIZE="1"]Мысль - это оргазм мозга. Те, кто способен его испытать - получают истинное наслаждение, остальным приходится имитировать.[/
