М2АI
The medium tank M2 was a larger development of the M2 Light Tank. Many components were common or used a similar design, including the vertical volute spring suspension which would be used in later tanks as well. Twin-wheeled bogies were mounted externally, and rubber-bushed and rubber-shoed track proved durable on roads. The M2 had a high superstructure with a sponson-mounted machine gun in each corner. In addition, two more machine guns were fixed in the glacis plate and fired by the driver. Surmounting the hull was a small revolving turret armed with a 37 mm Gun M3 and a coaxial machine gun. The crew comprised of the tank commander, a driver and four gunners. The vehicle provided internal stowage for 200 rounds of 37 mm ammunition and up to 12,250 rounds of .30-06 cal.
Specifications
Weight 18.7 tonnes
Length 5.38 m
Width 2.59 m
Height 2.82 m
Crew 6 (Commander, driver, (4x) gunners)
Armor 6.4–32 mm
Primary armament
1× 37 mm Gun M3
200 rounds
Secondary armament
7× .30-06 Browning M1919 machine guns
12,250 rounds
Engine Wright R975 EC2 air-cooled radial gasoline
400/340 hp (298/253 kW)
Suspension Vertical Volute Spring Suspension (VVSS)
Fuel capacity 473 litres (125 gallons)
Operational
range (130 mi)
Speed 42 km/h (26 mi/h)
